Throwing Codes - FirebirdV6.com/CamaroV6.com Message Board
Throwing Codes
  • Throwing Codes
    Ok so about 2 weeks ago I got headers installed. When I got it back it was misfiring so I got it scaned and it was throwing P0306 Cylinder 6 Misfire. So I changed the spark plug wires. Now I'm throwing a code P0420 for my Cat. Should I erase the codes and see if they come back before doing anything? Or do you think I need an O2 Sim because I got a Highflow cat on there now and it might be a bad O2 sensor?
    Re: Throwing Codes
    the miss went away? do you have to pass emissions?
    Team NoVa
      Re: Throwing Codes
      I'm not sure if the misfire went away yet I havn't erased the code yet. It deffinetly feels better though. I will have to pass emissions eventually yes
        Re: Throwing Codes
        How long was it driven when it was mis-firing? You might of blown your highflow....
          Re: Throwing Codes
          ^possibility, no fire means unburnt fuel could be all up in your cat. what are you using to pull codes?
          Team NoVa
            Re: Throwing Codes
            I did drive it for a while with the misfire, how would I know if the cat was blown?
              Re: Throwing Codes
              The light...
                Re: Throwing Codes
                Originally posted by ne0hisda0ne View Post
                The light...
                How the light doesn't tell me specifically What is wrong?
                  Re: Throwing Codes
                  it told you P0420 right? That's your sign. Your misfire made you run rich, which may have "exploded" in your cat under high temps, this in turn "may" have had adverse affects on your highflow. SO basically now your experiencing a "clogged" or "damaged" cat that is throwing your air/fuel mixture off and your O2 sensor is detecting it.
                  If it was never misfiring I would agree with you that you may just need an O2 simulator.
                    Re: Throwing Codes
                    again, how are you pulling codes?
                    Team NoVa
                      Re: Throwing Codes
                      Actron OBD II sorry it wasn't my scaner i had to find out what it was
                        Re: Throwing Codes
                        have you cleared the code to make sure its a hard code? ie. the code may go away for a bit, but will reset later on down the road.
                        Team NoVa
                          Re: Throwing Codes
                          today was the first time i seen the p0420 code and i just cleared it now when i looked at what the scanner was. Ill drive for a bit and see if it comes back along with the misfire code.
                            Re: Throwing Codes
                            do that and let post back up.
                            Team NoVa
