Two years ago I replaced my compressor and dryer due to a leak... Now my ac still blows cold but after several minutes of driving it starts blowing weak and eventually doesnt blow at all. ???? any help ?
a/c blowing weak and not blowing at all
Re: a/c blowing weak and not blowing at all
I think what insaneABOT is trying to say is did you check to see if the A/C clutch is still spinning when the AC stops blowing? Also when stops blowing, do you mean completely stops blowing or just stops blowing cold air? If it stop blowing all together you might have a "blower motor" issue. Maybe you have a short somewhere for it to start and stop?
I had a similar issue, brand new compressor, checked all the lines with a scanner thingy, to no results. i just ended up putting some freon in it and its ice cold now.
but it did the same thing as yours did, blows cold then just blows air.
dont know if this helped but its something to think about.
stops moving air completely when it stops and then will magically start for a minute or two (air remains cold) and repeat.... I have had a clicking noise coming from the blower motor location for atleast a year or two. I have not yet opened anything up to check that out. A/c clutch on the compressor or in with the blower motor?
alright so air completely stops? if so then no need to check the clutch.
clutch is what activates the ac system (the coldness), when the clutch is disengaged the compressor pretty much then just acts as a pulley. hence you'll still get air blowing just warm or hot air.
if your air completely cuts off and then a minute later starts blowing again, I'm willing to bet it's your blower or something to do with the blower circuit. a motor can be bought for cheap like $40 at your local auto shop...
I would investigate that clicking...you said you know it's the blower...is it coming from the passenger side under the dash? if so then pull your motor...test it while not mounted and still plugged into your car...use safety and don't be dumb with it...anyways, good luck...
oh sorry read it wrong i guess
Thanks for all the help, I'm gonna pull the motor tomorrow. Till then I'd rather be on my motorcycle than stuck in that car 20 miles from work when I gotta be there at 3:00 pm and it's 95 outside, dang cool Texas summers lol...
Okay figured out what the clicking was. When I pulled the old motor out the fan basket was full of leaves, this would probably explain why I quit hearing the clicking awhile back. I didn't bother putting the old one back in and testing it out with no leaves since the new one was only 40 bucks. Fairly easy install, I only cussed a couple times after dropping a screw. A/C hums like new now........
SCORE! Yeah I dunno about a "ticking" sound though...think that is the wrong way to describe it..I hear more of a "baseball card in a bicyle wheel" sound...but to each his own...our car is really bad about sucking **** in through the vents between the windshield and the hood...glad it's fixed...
