I'm guessing it's the starter. I have all power to windows and radio. I'm about to go check the battery voltage and amperage, and also try the short starter with a screwdriver trick. Any other advice? It's a 2001 Hyundai Santa Fe.
I would think it's just the starter but would a weak battery allow me to roll down windows and play the radio but not start the truck?
Re: So my wifes truck clicks when I try to start it..
Could be starter relay or IGN. wiring, I would say yes for a weak batttery to roll down windows and play radio, just doesn't have enough amps to start the truck. Could be a dead cell in the batt.
ok, so definitely not the starter, I had a buddy jump me and at it started no problem. so it's the battery right? I had him charge me up for 10-15 minutes and when I disconnected his cables I started it and again started with no hesitation.
when we checked the battery voltage it showed 11.6v and when we checked the amperage it actually didn't register, even when I tried to start it while a meter was hooked up to it.
or
could this be an alternator? radio and windows wouldn't work without the alternator would they?
Don't remove the battery cable from the battery with the truck running. You will be replacing the alternator. And probably some other electrical equipment. An alternator needs something to charge through, unlike a generator. I know people do this all the time, but it's just plain wrong.
ok, so tested it one more time...
took a volt meter..turned it to DC...it read 11.6v...when I started the truck the voltage dropped to about 9v, then jumped back up to 11, when I started turning lights and radio and ac on no drops in voltage...also when I revved the engine the voltage went to 13.6v...so with that I'm not thinking this is an alternator problem...more a battery problem...
well I already tried it...truck instantly died...
if truck stayed on I can see someone connecting the battery while it was still on and a voltage spike happening...which only a moron would do that...but removing it and the truck dying and then reconnecting it while the truck is obviously not on, I don't see any harm in it...
truck started fine btw after I did it...thinking though obviously that test don't work for this truck...as when I rev the engine the battery increases it's voltage and when I turn on devices that require power the battery doesn't drastically decrease in voltage...
Get the truck started, and run it down to Auto zone, discount auto, oreilleys, wal mart / sams club, any auto store (usually) and have them test the alternator.
Your alternator may be charging, just not efficiently.
Like you said, if you charge your battery fully, it will start and keep the car running for a while, until the voltage drops.
just called vatozone...said they don't need it removed...said they have a tool...guessing it's either a MicroVAT or DTAC...so wish me luck...I'm out...
well vatazone checked it with his tester, told him thought it was either the battery or the alternator, he hooked it up and ran the tests and said both are fine..???..says the battery reads a lil' low, but the tester didn't find anything wrong. ever since that jump and charge from my buddies car I've had no issues starting it. could the vatozone guy of done it wrong? he tested the circuit without me starting the car. does it need to be started to test the alternator? said a good 10-15 minute highway (above 2k rpm for 10-15 minutes, not stops) drive would fix the issue. wtf?
3 days ago
