Upper dash crack & Airbag Cover removal - FirebirdV6.com/CamaroV6.com Message Board
  • Upper dash crack & Airbag Cover removal
    My upper dash is cracked across to the point its broken and I called myslf trying to paint the airbag :omg: and that went sour :cry: so I was going to get the originals put back on. I found some off of a wrecked Camaro. So how Do I remove the upper dash without cracking so I can put it into my car and what about the Airbag covr how do I remove that aswell and place it into my car?
    Re: Upper dash crack & Airbag Cover removal
    upper dash should slide right out with no problem...other part....not sure.
    WAWA-A-HOLIC
      Kristen's right. To expand on that, the dash is held in by industrial hook and loop type fastener tape at a few points around it's perimeter. Pry up gently and it should snap out without further damage.
      I just had mine out after it cracked to glue, glass, and carbon fiber it from behind.
      Airbag... yeah, no clue either, be sure to disconnect the battery before messing around though.
