My upper dash is cracked across to the point its broken and I called myslf trying to paint the airbag :omg: and that went sour :cry: so I was going to get the originals put back on. I found some off of a wrecked Camaro. So how Do I remove the upper dash without cracking so I can put it into my car and what about the Airbag covr how do I remove that aswell and place it into my car?
Upper dash crack & Airbag Cover removal
Re: Upper dash crack & Airbag Cover removal
Kristen's right. To expand on that, the dash is held in by industrial hook and loop type fastener tape at a few points around it's perimeter. Pry up gently and it should snap out without further damage.
I just had mine out after it cracked to glue, glass, and carbon fiber it from behind.
Airbag... yeah, no clue either, be sure to disconnect the battery before messing around though.
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...3 weeks ago
