I was driving down the highway and my car's oil pressure gage started acting funny (moving all around), then I loose the ability to accelerate or brake so I pull to he side of the road. I originally though it was not enough oil in the car or the battery/starter was the problem. But after changing/adding oil and replacing the battery the car still won't start. Could this be a alternator, spark plug, or fuel pump/sending unit issue?
Does the car crank when you try and start it? Do the dash lights come on when you try and start it?
fire you can take off the plugwires off of coil packs and crank it over and see if there is spark and on the fuel rail there is a thing that looks like a valve stem take the cap off and push to see if there is fuel getting to it
