thank you for posting this..... i've been driving around with my windows stuck in the up position for a long time.... now i should be able to do this and fix them both.....
I would suggest going to a #10 screw. I have had the #8's come loose and break before. Might need to drill the hole bigger, but I have never had a problem with the bigger screws.
3 days ago
