Im new here and ive got a little problem. Ive got a 3.4 95 firebird. When i turn the key into the on position my cooling fan turns on and the cooling fan runs all the time . I believe having the cooling fan when trying to start my car is putting excessive drain on the battery. Anyone know what could cause this.
when it goes out, the car will run the fans 100% of the time
bingo!
you have two coolant temp sensors, even though your in dash gauge might be working, if the one that controls the fan is not your fan can stay on at all hours. have fun swapping it out, it's nearly impossible without taking off the upper intake. :D
Found the problem. It seems the guy who owned the car before me had run a wire from the cooling fan relay to ground. He must not have liked how long it takes for the fans to come on.
maybe he did that because there is something wrong with the car and it would overheat?
Thats not a bad idea , but there are other ways fi you want to spend about $85 for a SLP fan switch plug and play with a switch for high an low and off on it. I installed one on mine in about 20-30 mins at most. Great mod if you live in a hot summer area. So far I love it. I even have Hptuners to reprogram the fans but having the power to stop or put them on high at anytime is nice, esp. with a drilled 160 thermo. And will be installing a 3 core 750HP all ALM. radiator. Nothing wrong the way it is now except will it still turn on high speed if you need it?
the sad thing is, is that you can do the same exact thing for about $7 at radio shack
