parts needed for 3.8 swap for $800 - FirebirdV6.com/CamaroV6.com Message Board
  • parts needed for 3.8 swap for $800
    online salvage yard emailed me back saying that its $800 for a complete engine, transmision, computer, and wiring.
    what else would be needed.......intake, springs...????????
    1999 White Ford SVT Lightning.<br /><br />Hoping to dyno @ 450hp/550tq by the end of \'04.
    Intake and thats it. I believe the springs are about the same. I've 'heard' the 3.8 weights about the same as a 3.4
    <b> \'95 Camaro 3.4L A4 <i>Rikku</i><br />AutoX - Drift - Street </b><br />\"Sideways is faster.\"
      <blockquote>quote:</font><hr>Originally posted by andrew N.:
      what else would be needed.......intake, springs...????????<hr></blockquote>
      What year?
      Cable or electric throttle? Try to get those parts too. (from the pedal forward...)
      A non-traction control car would be good. Otherwise the pcm is going to be expecting some sensors and things on the rear end to be there.
        what are the emissions diffs between the engines/yrs? 3.8 might actually be cleaner & more power to boot [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img] :D
        2013 Ram 1500 Big Horn
        94 comero 3.4
          if your gona spend money on that i would see if you could swap an lt1, see what the price on that is you will like it a lot more!!!
            I am selling my 3.8 complete from harness to pcm
            including 5spd trans, drive shaft rear pretty much anything you would need. Its from 98 70k miles on the engine the trans is brand new. I am swapping an ls1 in mine so I could use the money quick. 500 for the engine and trans including all accesories. I also have the front suspension if needed not sure if the 3.4 and 3.8 mounts are the same.
            2001 Trans Am WS6 A4<br />SLP Lid<br />FlowTech Cutout<br />TNT F1 Dry Kit<br />Bone Stock 13.3@104.7<br />75hp Shot 12.0@117.8<p>1998 Camaro V6<br />LS1/T56 Swap<br />SLP Lid<br />Hooker Long Tubes<br />B&B Triflo Exhaust<br />B&M Ripper
              Dude, if your gonna swap engines anyway, just get the V8!!!!!!!!
                cant afford the v8.
                the timeslips page shows that 12's are attainable w/ the 3.8.
                  cant afford the v8.
                  <hr></blockquote>
                  Stick with the 6 ;) -- I miss my 3.4 once in a while, but wouldn't give up my 3.8.
                  -- But do find out what year it is and cross it against what you currently have. $800 is a good price for everything :D
                  Best of luck!
                  • Andy H
                    Transmission removal help!!
                    by Andy H
                  • 2.8 Bird
                    Abs inop
                    by 2.8 Bird
                  • fishin
                    by fishin
