ok im installing my a/c right now and i need some help asap - FirebirdV6.com/CamaroV6.com Message Board
  • ok im installing my a/c right now and i need some help asap
    i just purchased a remanufactured a/c compressor from autozone for 215.00 my question was im about to take out the old one and just wondering is there anything to it other than unscrewing it and caping off the tubing?
    i was also told that once you install the new you should run the ac before you recharge it to get all moisture out? is that right?
    and what about pag oil and all tht?
    just please give me tips and things to look out for this is my first time and i dont want to mess it up
    thank you rob
    Re: ok im installing my a/c right now and i need some help asap
    any one please?
      you need to drain the oil out of the compressor, there is a drain plug
      pour it into a measuring cup and see how much comes out.. buy that amount in little cans of PAG 46 iso oil (it is usually behind the counter) DO NOT use that oil that comes with the recharge kits
      fill the new compressor up with that much oil (im assuming the compressor will come oilless)
      and it is impossible to run the ac system before you charge it unless you short out the connector, and you will end up burning your system up.. just recharge it like normal and you will be good
      edit* and did i mention DO NOT use that oil stuff that you use the same way you would recharge the system?
