Like the title says. I just purchased a 95 3.4L and it runs much cooler than my last firebird. Im thinking previous owner might have pulled the thermostat. It takes it sweet time to inch its way a little above 160. Will running this cool hurt MPG?
Depending on temp outside , it should take about 10 min. to hit 160 temp. Here in AZ it takes my car 5 mins. to hit 160 degrees, this is with a drilled 160 thermo and manual fan switch on.
3 days ago
