Need Some Help ASAP - FirebirdV6.com/CamaroV6.com Message Board
Need Some Help ASAP
  • Need Some Help ASAP
    Hey guy so today i replaced my side mirrors and i had to take the door panel trim off a bit in order to undo the bolts from the previous mirror, and now this happened. theres a gap between the trim and the actual door. ive tried messing with it a fair amount but i was just curious as to if anyone can help me out or give me some advice. haha sorry if this is a dumb question/easy fix, id just appreciate some help. Thanks alot, robby
    Robby
    2001 Chevrolet Camaro 3.8 V6
    |JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
    http://speed-bros.com/
    Re: Need Some Help ASAP
    Looks to me like you just need to play around with the panel some more. I have not messed the panels on F-bodies, but on my other cars it sometimes took some time to get those panels back on properly.
      thanks bud, does anyone know exactly what to do? like which way to move things?
      Robby
        the inside black piece kinda hooks over the door where that gap is.
          X2 it hooks over and hangs on.
            x3... even knowing what to do, it probably won't happen for you on the first try, just keep playing with it until you get it... patience is key
            push it toward the door, and then while keeping pressure toward the door push down...
            Custom interior...
            TEAM NoVa
              put the flap over then go down. i believe this is how it works, sorry for the crude drawing
              Team NoVa
                I cracked the bottom on one of my panels after kicking it out of frustration. I hate putting those damn things on. So yeah, just be patient with it.
                TEAM C6V6
                  hahaha oh jeez man did u have to replace the whole door panel? im still tinkering with mine and still cant get it.
                  Robby
                    Yeah, they were a PITA to get them to "hook" correctly. I think I used to remove the corner triangle piece (opposite the rear view mirror) in order to get a little more room for the door panel to hook-over.
                      A little tip, have someone help you when you're doing it... line everything up the best you can, and have someone hold it toward the door near the bottom where the "hooks" are and then you hold it near the top and just ease it downward... I've done this to these doors like 6-7 times and it never really gets easier, I don't think I've ever gotten it on the first try...
                      Just figure out everywhere on the door panel that hooks into the door, and try and keep constant pressure on all those places while you move the panel down...
                      and most importantly... good luck, bc that's what really gets the door panel on right is luck
                      Custom interior...
                      TEAM NoVa
                        I suggest you go to home depot and get some silicon spray, spray the area that needs to be connected so you can reduce the resistance. I replaced my passenger mirror
                        two weeks ago but only pulled the inside door panel just enough to remove the bolts
                        that held on the old mirror. I know what you are going through and its a *****. If all else favors, go to a body shop at the chevy dealer and say " I wonder if you could do me a FAVOR? Could you get this door panel back for me?"
                          Its definitely a pain in the *** to put those panels on. The key is really getting each hook and the top flap to get into their attachment points at exactly the same time. I find that the part up near the front by the mirror sometimes is not in while everything else is. In this case just give it a little punch and it should snap in.
                          Like everyone else said, you'll rarely get it the first time, I dont think I have after doing it on 3 different f-bodies for window motors, speakers, window adjustments etc.
                            Yea sometimes it can be a pain in the @ss, but its never really taken me more than 1 0r 2 trys, You gotta do like blizzard says, angle the door panel, hang the top as you push toward the door and then down.
                            *Matt
