Trans-X(chemical) used in crank case - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Trans-X(chemical) used in crank case
    well..mr flaming chickin.
    trans x is NOT a tranny fluid. it removes sludge/varnish (stops slip) conditions bands and seals WHICH prevents leakage
    you think i dont know anything, which is lame. cause i know quite a bit BUT do not claim i know everything like you do.
    anyways one guy said he was gonna use it in his rents van.
    try it. cause i swear it works. my friends truck that had a chevy sbc. burned so much oil cause cyl. 7's ring was shot. and the valve seals were EFFED>so in turn i put sometrans x in it and now it only burns about2 quarts every to weaks(due to the bad ring)
    i would recommend this chemical to anybody with a oil burning problem or a leak problem.
    now i dont know if it would remove stains or any of that. but i do know it works well with trannys and engines.
    (trans x fyi. is sold at EVERY walmart. EVERY autozone. EVERY advance auto and EVERY K mart.)
    Re: Trans-X(chemical) used in crank case
    Hmmm, that other thread was closed for a reason.
    I dont want to be mean to you, but you are asking for it by making another thread like this
      why was it closed? when was it closed?
      i replied to the other thread?
        for ****s sake, youre done.
        Follow me!
        Or this
