I'm starting an engine swap (96 3.8 out and 99 3.8 in - both RWD). I know I have to change the intake, but does anyone have any advise as to what other problems I may run into?
Engine swap
Re: Engine swap
depending ont he mileage, you amy want to change all the gaskets you can. if you buy the conversion kit from autozone, it comes with the oil pan gasket, rear main seal, oil pan gasket, water pump gasket etc. and it's only like $35Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Re: Engine swap
Might have to swap the balancers. Since 96' and 99' are different.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Engine swap
Are there any lists of the differences between engine years (off topic, I think it would help the OP as well)? Id like to get a JYard engine and slowly rebuild it while the other one dies. And hopefully have it done by that time.sigpic
98 Camaro 3.8 M5 Y87 | 99 Camaro LS1 Z28 T56
