A/c Delete - FirebirdV6.com/CamaroV6.com Message Board
A/c Delete
  • A/c Delete
    So today I finally got unlazy and decided to delete the a/c out of the car...fought with the condener for a good 20 mins...but what really has me stumped is the bolts on the compressor...I read there are some bolts on the back...more specifically a 15mm...well I took out all the bolts on the front, and it looks like the only bolt that is holding on the compressor is the bolt that holds on the ground for the engine? I didnt read anywhere that this bolt holds the bracket? Whats the deal with this...I cant get that damn bolt off, bot nuts and the bolt itself turn when I try to undo it, and it just twists the copper grounding piece...
    Re: A/c Delete
    Its been a couple years since, but I do know there is a bolt in the rear of the compressor, might be the same one that holds the main battery ground on the engine as well.
    1995 Pontiac Firebird
      Re: A/c Delete
      idk if our compressors are the same but there was a bolt on the back of the compressor that was a stud so it didn't seem like a bolt at first and it's a real pita to get at.
      try checking the back of it again you might have missed one.
        Re: A/c Delete
        hope it helps
        Team NoVa
          Re: A/c Delete
          i hope you dont use a fram.
          and as for the ac delete.
          i just TOOK OUT the WHOLE bracket.
          then took he ac off of it. then bought a belt to fit the rest of the pulleys.
          i can give u the specs for the belt.
            Re: A/c Delete
            You can get an AC delete bracket pulley z38.
              Re: A/c Delete
              i know. but i didn wanna pay the extra 30 or 40 to get it.
              so i went to o reighlys and got a belt ( its off a 1988 ford ranger 4 cyl.) thats the size.
              its fits like a dream.
                Re: A/c Delete
                or you can take a string and run it through the pulleys. Then measure the string and take that number to a parts store and they will give you a new belt that way
                  Re: A/c Delete
                  yup. all day long.
                  Team NoVa
                    Re: A/c Delete
                    ahh...The ground bolt wouldn't budge...the bolt and both nuts kept turning...even when I tried backup wrenches...Plus it was twisting that copper ground up so I left it alone...had the mechanic remove the damn bolt...apparently there were a few more, but that was the entire bracket that came off....I now have no a/c compressor, condenser, drier, upper idler pulley, or any of the brackets that held that stuff on....made ALOT of room...well worth the frustration lol...
                    Thanks for the help...I would of kept goin at it, but if I broke that engine ground off I was gunna be screwed...
                      Re: A/c Delete
                      Yeah...I was really suprised how much room there is on the passenger side once the compressor and the rest of the AC gear is removed. I don't regret it one bit, sucks at times, but I don't regret it.
                        Re: A/c Delete
                        i never used the damn thing when it worked...had a buddy in the buisness fix it once for free...didnt last long...didn't feel like trying to figure out where the leak was....just took the whole thing out...can notice a slight difference when driving...but then again I notice the small things like that...I felt a difference with my spare and jack out to...
                        definetly makes the job for the poly motor mounts look much easier now...
                          Re: A/c Delete
                          Keep us informed....might have to try that myself.
                            Re: A/c Delete
                            will do...they are sitting in my trunk at the moment until I can figure out what to do about my oil pan...Im having to add atleast a quart of oil to my engine between oil changes now...don't see any oil on the driveway, only onto the Y pipe...Flywheel is dry so its not the rear main...has to be the oil pan I guess...plus it looks like its starting to rust out...lucky me...
                              Re: A/c Delete
                              Could be the rear cover. Its a longshot, but there is a rear cover on our engines, all it is basically is a plate with an oil valley in it. But its possible, seeing as it does have a gasket.
                              • 187shark
                                by 187shark
