Car running sluggish - FirebirdV6.com/CamaroV6.com Message Board
  • Car running sluggish
    For the past month or so I've noticed that my car has lost some of the get up and go it once had and i've lost some mpg's also I changed my spark plugs I got the e3 ones,that made a little difference but not much. I know it's hot and the ac might suck some out but I don't remember it being like this last year....Any suggestions?
    Re: Car running sluggish
    Could be a hundred things.
    1. Air filter clean?
    2. Change plug wires & coils if need be
    3. Fuel Injectors may be dirty (try using a can of sea-foam in your fuel tank)
    4. carbon build up (try sea-foaming the engine)
    5. Clogged / Dirty Fuel filter, replace it
    Those are the most common things Id say.
    Id start with a clean air filter, and 2 cans of sea-foam and see if that helps.
    *Matt
