How to sucessfuly reset your computer - FirebirdV6.com/CamaroV6.com Message Board
  • How to sucessfuly reset your computer
    I tried this with a little advise from someone else on the forum(cant remember the name sorry)
    But this is what I did: Turned key to the last click before actually turning on the car then pull two PCM fuses BATT then IGN in that order... I believe the PCM batt is a big 50 fuse... After you pull the fuses you will hear a click or somthing like that. turn key back to off and replace the fuses... This was the only way that I could reset my SES light and a few other faulty items. I tried the battery disconnect and jsut pulling fuses, you have to dothe key thing... Hope this helps anyone needing help, and if I might have said somthing wrong... correct me.. I am bad at giving directions...
