I have a 97 firebird, which still has the original radiator in it. I just found out the other day that it is leaking on the edge of it. I just bought a new radiator for it and was wandering how hard is it to replace it yourself, or if it would be easier just to go pay and have it done?
Help! Radiator change!
Re: Help! Radiator change!
it takes about an hour or two to do it your self. real easy. take the support off, 4 screws at the top near your air filter base.
then the fan is clipped in, pull up and out on it and set it back. unhook your hoses and the radiator slides out...super simple.
on a scale of 1-10 i would rate it 3 tops.Team NoVa
Its actually quite simple in a V6 fbody. You'll have to remove the radiator hoses, the cover for the top of the radiator (has all the car and engine info stickers on it). Should have a couple of retainers of some sort, then it just slides out.1995 Pontiac Firebird
your a machine kristen.Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
