weird grinding noise? - FirebirdV6.com/CamaroV6.com Message Board
  • weird grinding noise?
    I got a grinding sound coming from my passenger side rear wheel, I'm thinking maybe wheel bearing, because I just put new brakes on it. Anyone have any ideas?
    Re: weird grinding noise?
    Could be a stone on the drum if it still has drums or I have seen a stone lodge in between the rotor and the backing plate as well make aweful sounds. lift it up and see if there is play in the wheel if there is play then likely a bearing if none then could very well be a stone.
