I thought my car was the only one like that... my 98 is 3/4" lower on right front and 1/4" lower on right rear. I didn't notice if the rear was worse before I replaced the shocks, springs, and panhard bar.
Mines about the same 27" front and 28" rear, QA-1 adj. springs shocks on the front and 1LE rear springs with Blisteins HDS on the rear(soon to be QA-1 adj. on the rear). I raised mine back up for my under the K turbo kit. Also the UMI tunnel mount TQ arm scraped a few times, so it needed more height. This is with 275/40/17's with 35 PSI in the tires.
Air pressure in the tires the same Psi all around?
X2 good ? , I keep mine at 35 PSI all way around edited my post for tire size also.
F-bodies have a tendency to lean a little more on the passenger side. I don't know the technical reason, but have heard that it may be to offset the weight of the driver. It's typically more noticeable with worn or aftermarket suspension parts.
'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
im wondering if my sub/stealthbox could be causing the drivers side rear to be a little lower.. even though the passenger side has the tire/jack
