blinker - FirebirdV6.com/CamaroV6.com Message Board
blinker
  • blinker
    My blinker looks like its on its last leg. Is there is certain circuit or fuse that controls the blinkers? If nothing else I can probably get the dealership to fix it, my warranty still has a little bit left.
    what do you mean last leg? do you mean that the blinker light is getting dimmer? You probably just need to change the bulb.
    <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
      True. Check your bulbs. I was sure that I had a shot flasher, but it was just a bulb. Very deceiving little part. It didn't give me the quick-flash like every other car I've owned, it just stayed lit on the dashboard.
      \'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
        just go down to autozone and pick up a bottle off blinker fluid that should fix it.. :D
        jeff
          just strange that both blinkers would go out at the same time, the left driving light just went out so i'll pick up some new bulbs and see if that does the trick. the ground could have gone bad i guess
            Has it been raining a lot?
            Water + Hot Bulb = :(
              ok, just replaced both blinkers, the one that blew out obviously shines now but they are both still doing the staggered blinking. guess i'll take it to the dealer tomorrow morning
                update: flasher relay had internal failure, dealer replaced it under warranty.
                woohoo i have fast blinkers again! :D
                  Alright, here's what you do. Turn on your blinker and get out of the car and check the front and see if it's working. Then check the back and see if it's working. If one is the back is lit and the front is out, it's the bulb, or vice versa. If both aren't working then think that it's not the bulbs. You can also try the hazards. Don't take it to the dealership if it's just a bulb, they'll think you're a moron. :D
                    <blockquote>quote:</font><hr>Originally posted by TheBeast:
                    ok, just replaced both blinkers, the one that blew out obviously shines now but they are both still doing the staggered blinking. guess i'll take it to the dealer tomorrow morning<hr></blockquote>
                    <hr></blockquote>
