My blinker looks like its on its last leg. Is there is certain circuit or fuse that controls the blinkers? If nothing else I can probably get the dealership to fix it, my warranty still has a little bit left.
blinker
what do you mean last leg? do you mean that the blinker light is getting dimmer? You probably just need to change the bulb.<b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
True. Check your bulbs. I was sure that I had a shot flasher, but it was just a bulb. Very deceiving little part. It didn't give me the quick-flash like every other car I've owned, it just stayed lit on the dashboard.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
Alright, here's what you do. Turn on your blinker and get out of the car and check the front and see if it's working. Then check the back and see if it's working. If one is the back is lit and the front is out, it's the bulb, or vice versa. If both aren't working then think that it's not the bulbs. You can also try the hazards. Don't take it to the dealership if it's just a bulb, they'll think you're a moron. :D- JT3<br />1998 Red V6 Camaro Y87 Y3F - J.E.T. Chip Stage II - Clear Parking Lights - Removed Grill - K&N - Whisper Lid - !FRA MOD - MAF Screen Removed - Pro 5.0 - Pacesetter Headers - Magnaflow Catback - 32mm Front Swaybar - And A System(bump bump)
<blockquote>quote:</font><hr>Originally posted by TheBeast:
ok, just replaced both blinkers, the one that blew out obviously shines now but they are both still doing the staggered blinking. guess i'll take it to the dealer tomorrow morning<hr></blockquote>
update: flasher relay had internal failure, dealer replaced it under warranty.
woohoo i have fast blinkers again! :D
<hr></blockquote>
