Well, I've been noticing lately that my motor has a weird idle to it. It idles at around 1,000 RPM, then it goes below 1rpm then shoots back up and all over again. It sounds like it wants to stall out but it does not. I was just wondering if any of you have ever had this kind of thing before; and what did you do to fix this. Throttle position sensor is what I am leaning towards. I've changed my oxygen sensors earlier this week so it's definitely not that. Any ideas?
Motor idle.
Re: Motor idle.
Originally posted by jimmysprinkle View PostAre you throwing a SES code for the EGR? Try this: Unplug the EGR-to-Intake hose, and have someone plug the hole with their thumb. Try idleing the car like that. If the problem goes away, then it's the EGR. Don't want to replace unbroken parts though, haha.Last edited by Leonard 3.8L; 07-17-2009, 10:20 PM.
Re: Motor idle.
When cold the HPtuner files have the idle at around 900-1000 RPMs once warmed up it has idle at 750 RPMs. But I would look at the IAC (idle air controller), or a small cracked vac. line with small laek.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Motor idle.
Originally posted by Mighty Thor View PostThis happened to my 89 bird and it was the EGR that was the problem.
