Misfire Issue - FirebirdV6.com/CamaroV6.com Message Board
Misfire Issue
  • Misfire Issue
    Ok, so I just got done changing 2 spark plugs and all 6 wires. I start the car up and it is now rumbling and misfireing regularly. I scanned it and its throwing a P0420 cat code, and a random cylinder misfire code. Could it be an o2 sensor throwing off the car causeing it to misfire. Anything else it might be?
    Re: Misfire Issue
    check the coils and icm
      Re: Misfire Issue
      Coils...
      Leonard
      www.fquick.com/96V6Junkie
        Re: Misfire Issue
        so upon further inspection turns out one of my wires fell out, and burnt. Changed it and its no longer rumbling but still has an occosional misfire under harder acceleration.
        How can I test the coils to see if they're bad?
          Re: Misfire Issue
          Change one and you'll know.
          Leonard
            Re: Misfire Issue
            im not gonna buy one if I dont need it
              Re: Misfire Issue
              If you have meter you can check it.
              Leonard
                Re: Misfire Issue
                i have a quick question, what does a misfire feel like when driving?
                  Re: Misfire Issue
                  The car stutters and shakes and feels like ur losing alot of power, idk really how to explain it more then that
                    Re: Misfire Issue
                    take the coil off and take it to your local auto parts store and they will be able to tell you whether or not its bad. take all of them in along with the icm and have it all checked while your at it
                      Re: Misfire Issue
                      It will sound like it's running on 5 instead 6 cylinders.
                      Leonard
                        Re: Misfire Issue
                        it will feel like its running on 5 cylinders instead of 6, and you probably will not have a very crisp throttle response either
                          Re: Misfire Issue
                          Same thing. It will feel like it's about to stall out.
                          Leonard
                            Re: Misfire Issue
                            yep and your idle may jump around a little bit....not sure if weve mentioned that one yet or not haha
                              Re: Misfire Issue
                              So my idle is fine car stopped rumbling and shaking and runs right most of the time but i'm still getting the bad throtle responce under acceleration. Though the ses isn't flashing
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
