Oil pan - FirebirdV6.com/CamaroV6.com Message Board
Oil pan
  • Oil pan
    i have a very small/ slow oil leak...it kinda sucks
    Can i replace the oil pan gasket with out removing the trans? I feel that i need to remove the trans to get to the pan...
    :wavey:
    Re: Oil pan
    I'm not sure if you can replace the pan without removing the k-frame.
      Re: Oil pan
      hmm true..
      lol im kinda using this thread to think out loud..
      I feel that the oil leak is because of the oil pan gasket..but you never know with oil leaks xD
        Re: Oil pan
        you can replace the oil pan gasket without removing the trans/k member
          Re: Oil pan
          yes oil pan can be removed with out trans removed or k member but will have to raise engine off motor mounts to do so
          1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
            Re: Oil pan
            If you decide to do it by dropping the tranny the only problem is that you have to remove the oil pick-up with the oil pan still partially in place. If you do it this way, you will see why its difficult.
            1997 Camaro RS A4
            2006 Chevy Colorado
            2003 Kawasaki Ninja ZX6-R
              Re: Oil pan
              thanks all!! Im gonna try this in a couple of days..since im taking off the mounts for the engine, i might as well change them along with the gasket :)
                Re: Oil pan
                im confused, you dont have to remove the oil pan to replace the gasket
                  Re: Oil pan
                  ^this, and you'll have to loosen the k-member bolts a few turns to remove
                  the oil pan. I didn't have to remove the oil pick up tube when I did it. If you
                  remove the nut from the trans mount you'll get a little more wiggle room also.
                    Re: Oil pan
                    I never said you had to remove the oil pan completely, but you do have to remove the oil pick-up and with the K member in the way the oil pan doesnt drop down very far making it quite difficult to remove the forward 8 mm bolt that holds the pick-up in place. Make sense?
                    (this is only if you drop the tranny and dont raise the motor)
                    1997 Camaro RS A4
                    2006 Chevy Colorado
                      Re: Oil pan
                      it would be better to remove it just to be certain that all the old gasket is completely gone..
                        Re: Oil pan
                        well the main goal here for me is to not drop the tranny, i hate doing it lol..i was just seeing if it could be done without removing it. i was told i had to, but apparently i dont :):banana:
                          Re: Oil pan
                          Are you sure it is the GAsket and not the pan on my 94 Bird before I started the restore on it had a leak and it looked like the gasket but was actually the pan it had rusted so thin that the oil was actually seeping out of the pan causing the leak. After the pan was removed and inspected it looked solid enough but if you looked really close you could see pinholes in the pan. Just a thought.
                            Re: Oil pan
                            I am in the middle of doing this now. I dont see how dropping the trans will help getting the pan out. Right now it is the exhaust Y pipe holding me up, it runs in front of the trans and under the rear of the oil pan. With the Y pipe there the rear of the pan wont drp down. I am still not sure if you can get the engine up high enough to get the pan out but at least from this thread I now know I can pull off the pickup and it will come out.
                            Scott
                              Re: Oil pan
                              good thought, ill check it out..cause mines a 96, so i mean its not far from yours. thanks.
