How do you remove the center console/cig lighter/ tape/cd holder on a '95?? I'm trying install my fan switch and would like it to go above the cig lighter. I can't figure out how to get the cig lighter off in order to run the wires and drill the hole. Thank!!!
How to remove....
How to remove....
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....Tags: None
Sounds like you just want access to the cig lighter wires. Just remove the clip from the back of the lighter and remove the console. The console is primarly held down by bolts inside the armrest compartment. Take those out and it should come up. Then all you'll have to worry about is the shifter and e-brake handle. You might be able to get to the wires without having to remove them. Since I don't know what a 95 Camaro console looks like I can't go into more detail.
Ya, and get a Haynes manual :D~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
Ok next question...How do you drill a 11/16 inch hole in your console?? I bought a 5/8 drill bit b/c I couldn't find a 11/16 and the darn thing doesn't fit in my drill..Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Oh and by the way I have a Haynes manual doesn't say anything about the lighter...Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Only thing I could suggest if moneys tight and you don't want to buy a new drill with a bigger chuck use the biggest bit that fits the drill then use a smaller bit and walk it around the edge till it is big enough.98 bird <br />160,000 miles<br />13\'s? Just happy it\'s starts every morning. <br /><br />Traded in @164,000 On a 2001 Formula
Maybe try a reamer that get progressively larger? Should make a nice cut...Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
I just walked the bit around the outside, took some time but it worked alright in the end, thanks for the help guys!!!Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
