Today when I was driving after coming out of a turn my car started wobbling in the front, and after thinking I remembered my Steering Rack n Pinion had been leaking, but latley it hasn't leaked anymore and now my car is wobbling. Is it possible that my rack is getting worse? Can it pop or Snap? How much time do u guys think I have before somthing serious happens?
Car wobbling bad :-( HELP
Re: Car wobbling bad :-( HELP
I wouldn't drive it until you figure out what's wrong... if your tie-rod or something goes out, anything could happen... my uncle lost a tie rod in his truck and his wheels pigeon-toed... luckily he was on a side-street only going like 25mph
Does it wobble back and forth or is it more of a vibration? Does it seem to be caused by either R or L wheel more?Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
well, we have to diagnose the problem before you can get a price.
go grab the right and left wheels (one at a time) at 3 o'clock and 9 o'clock shake it side to side. like you are trying to turn the wheel, if you hear a noise or feel it move relatively easy, then stop, its more than likely a tie rod. get a buddy to do it while you go under and see what is amking the noise.
it is the front of the car yes?? not the back wobbleing? have you hit a curb? could be a bent wheelTeam NoVa
Pics to help with the wobble threat
all pics are taken with the tires off. This is the passenger side does anything look out of place? I took the tires off and put them back on and now it doesn't wobble as much anything messed up down here?
These are pics of the drvr side...again does anything look out of place. Thanks guys for the help!
Jack the car up, and have the front end on jackstands, move the wheels side to side with your hand while under the car and see where your getting the play from.
Id also pull the wheels off and check your studs, make sure you havent broken any studs or have any loose lugnuts.*Matt
Originally posted by StrtRacer98 View PostJack the car up, and have the front end on jackstands, move the wheels side to side with your hand while under the car and see where your getting the play from.
_________________Team NoVa
