Ok so i went to turn on the car and it started fine. I tried to back out but the car stalled, i assumed it was because the engine was cold. I start it back up and i get a reduced engine power light. Car loses power and all. i go and take off the throttle body and theres coolant in the throttle body and intake manifold. Also there was some smoking in between the intake manifold and the coils (somewhere down there couldnt see well). what could be wrong? assuming tps again
update on past problem
Re: update on past problem
#1 yes there should be coolant that goes from your upper intake to your tb.
#2 i would take the upper intake off just to see whats going on in there. and to just changed the upper intake gasket to be safe. you could have a leak...but i dont see how that would get you a light
