Ok, I am going to race a 95 M5 3.4 Camaro in May, and want to be at least 90% confident that I can beat him. I have a K&N FIPK, some kind of dual exhaust, and a B&M shiftplus. What do I do next? I dont want nitrous or forced induction, or headers. Any ideas or suggestions? I want to be like this [img]graemlins/toto.gif[/img] and him like this :eek:
What should I do now??
White 94 3.4 A4 Camaro<br />Perf:<a href=\"http://www.splmeter.com/94camaro.html\" target=\"_blank\">2.5\" Flowmaster catback </a>, K&N FIPK, B&M ShiftPlus, Aluminum Driveshaft<br />App: 17\" Eagle 077 wheels, rk sport performance spoiler, clear corners<br />Audio: <a href=\"http://www.splmeter.com/box.html\" target=\"_blank\">Drivers side 12\" stealth box</a><br />Times: 10.602@64.2 w/ 2.25 60\' in the 1/8thTags: None
I was under the impression that upgrading coils, plugs, and wires was pretty useless.I heard that you do not get any extra power from it, but I guess I am wrong. And a driveshaft would free up extra hp lost on the way to the wheels right? How much more expensive is an aluminum one compared to steel? Thanks
free ram air mod tb bypass and do some weight reduction1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
Ok. Aluminum driveshaft is about 200-300 installed. Remove your spare tire and jack. get a whisper lid for 125, remove your maf screen, and raise your air box. Thsi will give you better throttle response off the line as well as more hp/tq. A exhaust cut-out installed for about 50 will help reduce backpressure for better throttle response and more hp/tq as well. you can get a jet chip or HPP3 for 300-350 and get firmer shifts, more spark advance, removed rev limiter, adj. shift points, and compensate for gear changes. wider rear tires will help off the line as well as a limited slip diff. from slponline.com for 90. tires you can get for 100 a piece or so. Hope this helps.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
<blockquote>quote:</font><hr>Originally posted by OnixV6:
whatever you do, don't do these.<hr></blockquote>
I agreeMatt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
Hey what can i do next i already have port and polish heads, three angle valve job, bored cycl over 20 and exhaust. Should i do headers, ignition, or excrude hone intake lower, upper and throttle body. And if so with the intake what kind of gains will i seeMy new ride 2000 camaro, No mods yet still waiting for warranty to run out then all out heads, cam, and supercharger
Hey Spookydink, it might help if we knew what year YOUR car is. If it is a 94, which I am assuming from your user name, you won't have to worry about the whisper lid mods. Info would help.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Yeah sorry, it is a 94 3.4 A4. And I cant do the whisper lid/free ram air thing because I dont have a 3.8. Thanks for all the ideas and help. [img]graemlins/fluffy.gif[/img]White 94 3.4 A4 Camaro<br />Perf:<a href=\"http://www.splmeter.com/94camaro.html\" target=\"_blank\">2.5\" Flowmaster catback </a>, K&N FIPK, B&M ShiftPlus, Aluminum Driveshaft<br />App: 17\" Eagle 077 wheels, rk sport performance spoiler, clear corners<br />Audio: <a href=\"http://www.splmeter.com/box.html\" target=\"_blank\">Drivers side 12\" stealth box</a><br />Times: 10.602@64.2 w/ 2.25 60\' in the 1/8th
Spootydink:
I'll save you a lot of time. If you are not interested in building a system, and want the most bang for the buck to beat this guy, get gears and LSD. That will give you the seat of the pants feeling. If your tires are bald, get stickier ones. You can do that other stuff later if you want. Don't remove maf screen. Do the gears soon, and you'll have them "broke in" just in time to beat him.
[ March 28, 2002: Message edited by: AMinor65 ]</p><b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
<blockquote>quote:</font><hr>Originally posted by Patrick Javert:
Ok. Aluminum driveshaft is about 200-300 installed. Remove your spare tire and jack. get a whisper lid for 125, remove your maf screen, and raise your air box. Thsi will give you better throttle response off the line as well as more hp/tq. A exhaust cut-out installed for about 50 will help reduce backpressure for better throttle response and more hp/tq as well. you can get a jet chip or HPP3 for 300-350 and get firmer shifts, more spark advance, removed rev limiter, adj. shift points, and compensate for gear changes. wider rear tires will help off the line as well as a limited slip diff. from slponline.com for 90. tires you can get for 100 a piece or so. Hope this helps.<hr></blockquote>
Ok whisper lid doesn't exist get a cold air intake. Can't raise the airbox there isn't one same with the MAF screen. Cut out will hurt you V6's need the back pressure to have any torque. Go for HPP3 if you can find one it is way better than the Jet chip. Coils will help a little not so much on power but better efficency. The BEST mod you can get is the LSD slp has them on sale right now for $85 I believe. Hope that helps.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
<blockquote>quote:</font><hr>Originally posted by Blue Flame V6:
The BEST mod you can get is the LSD slp has them on sale right now for $85 I believe. Hope that helps.<hr></blockquote>
I ordered my best friend that part for his 89 T/A in mid February and I'm still waiting for it to be delivered! I called them and they said that it's sent as soon as the order goes through. I guess since I am in CT, they will have someone deliver it to me on foot... cuz it's taken more than a month for a 3 and a half hour drive :mad:<b>Sean: 1994 Camaro daily driver</b>
<blockquote>quote:</font><hr>Originally posted by Liquid Silver:
...cuz it's taken more than a month for a 3 and a half hour drive :mad: <hr></blockquote>
SLP is slow as $#!T delivering parts. :(
(But I did get 4 new shocks and springs for like $75! :D )-James<br /><br />\'96 3.8L A4 Camaro (SOLD)
So how much time could I take off of my 1/4 mile with LSD? With 3.42s? With both? ThanksWhite 94 3.4 A4 Camaro<br />Perf:<a href=\"http://www.splmeter.com/94camaro.html\" target=\"_blank\">2.5\" Flowmaster catback </a>, K&N FIPK, B&M ShiftPlus, Aluminum Driveshaft<br />App: 17\" Eagle 077 wheels, rk sport performance spoiler, clear corners<br />Audio: <a href=\"http://www.splmeter.com/box.html\" target=\"_blank\">Drivers side 12\" stealth box</a><br />Times: 10.602@64.2 w/ 2.25 60\' in the 1/8th
