I have an emergency problem tht needs to be fixed asap ! - FirebirdV6.com/CamaroV6.com Message Board
  • I have an emergency problem tht needs to be fixed asap !
    So I was driving tonight and out of no where some of my interior lighting goes out like my tempature settings and my light control then I get pulled over and find out that my tail lights are out?? But my brake lights still wrk and my dash and also my day lamps are out to??? And there's no blown fuse and I need to figure thus out before I have to go to wrk again tommorow !!! And one more thing when I lock or unlock my car all my lights blink including my tail lights and my interior lighting !?? What the he'll is going on??
    I have a 98 firebird
    Thank you,
    rob
    Re: I have an emergency problem tht needs to be fixed asap !
    if you have keyless entry and you unlock the doors, i would think they would light up. but idk about all the other stuff, if its not the fuses, maybe a loose connection somewhere around the computer system or something?
      i know you said you had no blown fuses ... but im assuming you only checked the ones for the lights or accessories ... check the horn fuse..... seriously
        so ive litterally checked every stink'en fuse in each fuse box and even replaced some older ones still NO LIGHT!!!
        ive even checked the horn fuse and nothing ? what the hell is going on i need a car i can drive at night !! its my daily driver!!
        I NEED YOUR GUYS HELP ASAP please
        Lights that are not working...
        1.interior red lights (light switch, a/c dials)
        2. my day lamps which are tied into the switch thats out aswell on interior
        3.Tail lights are out when headlights are on, but my brake lights DO wrk.
        and as too changing my horn fuse i already did in the box under the hood but if it means anything my horn did go out last week and havent replaced it yet?
          hmmm have you checked EVERY Fuse ?
            this happens to me , my hazards/brake light fuse starts "tripping" other fuses and makes my cig. lighter and obd2 port stop working till i pull the hazard lights fuse and put it back in
              Ok so ive done EVERYTHING!!!! ive took fuses out changed fuse checked EVERY fuse and still nothing ?
              i might have to just take it in for this one i really need to get it done fast this is my second night driving wioth no rear lights!!!
                he said he did :twak::twak::twak:
                headers, high flow cat, slp loudmouth
                powerdyne supercharger 6psi
                GT2 cam. all done by myself :banana:
                Hell yea
                  check your fuses, bring it to a dealer ship if you can. i had the same problem i had no lights on at night, no dash light anything but my running lights etc did work. brought it to a dealership and it was a fuse, i checked them myself and also found no problem it was a fuse i totally didnt even realise. good luck
                    Originally posted by winnipegcamaro View Post
                    check your fuses, bring it to a dealer ship if you can. I had the same problem i had no lights on at night, no dash light anything but my running lights etc did work. Brought it to a dealership and it was a fuse, i checked them myself and also found no problem it was a fuse i totally didnt even realise. Good luck
                    how much did the dealer charge u?
