I read the how to on fuel pump is there any way to do it dropping tank without dropping rearend I have a lift at my dads and we were not sure its my next saturday project
changing fuel pump
Re: changing fuel pump
I personally like my access panel myself and I have a dynamat cover for it so it is totally sealed.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by scream97 View Postcan i use a fuel pump from a lt1 on my 3.8 camaro.
You can ditch the bucket and use hose clamps to put eveything together, my Walbro 255 pump was plug & play for wiring this was on my 96' Camaro. Just make sure you get everything tight or you'll be dropping the tank again if you go that route or just doo the access panel which takes 15 min. at most to get in and out to check the pump once the access door is cut.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I've dropped the tank without dropping the rear, and I didn't cut an access panel. It's a real squeeze but I got it done in about 1 1/2 hours. Jus make sure you have someone to bend the filler tube when you're trying to pull the tank.
by fishinI usually have to double, triple my headlight switch for them to come up on my 97 Firebird. I cleaned all connections. Could it be the headlight switch...4 weeks ago
