can anyone please tell me where i can come by a new cam and rockers for my 1995 3.4L camaro?
desperately need 3.4L help!
i am gettting my roller rockers from summit and you can either buy a comp cam or get one custom made there was someone selling a comp cam in the for sale section for our car hope this helps [img]graemlins/fluffy.gif[/img]1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
are there any decent priced 1.6 ratio roller rockers available? what about just a plain ol 1.6 ratio rocker?Black 1995 3.4L V6 \"<b>THE BLACKBIRD</b>\"<br /><b>Performance Mods </b> K&N Fipk, Hypertech Underdrive pullies, Accell Coilpacks, and wires, rapidfire plugs,180 degree thermo, 1LE Tranny Mount, Z28 Catback W/crome tips B&M Ripper shifter<p><b>Appearance mods</b> 2 1/2% Limo tint all around, Blacked out taillights, turn signals, and side markers, red PONTIAC rear Inlay, 98+ style centerplate bird and graphic<p><b>Stereo System</b>Panasonic Cqdf 800u head unit, 2 MTX thunder 280 amps bridged, 2 Cerwin Vega AI 12\'s on the rear deck, 6x9\'s in the rear sail panels, Monsoon Door panels With Memphis Audio 6.5\" Coaxials and tweeters, 1 farad EFX cap.
Get the CAM from Jegs. The kit including lifters is $159.00 (270-254122)
http://www.jegs.com/cgi-bin/ncommerc...br=76&lastcat=
[ March 07, 2002: Message edited by: stagen ]</p>94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
You do not necessarily need springs but they wouldn't hurt. A bit more work though.94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
With any change of rocker ratio or cam lift change you need to do some major checking first...
Your current springs may bind with any change in lift (rocker ratio or cam lift), and this will require a change in spring. Depending on the cam/spring/retainer combo, machine work may also be required on the spring seats and valve guides.
There may be other options that will get you around all the problem stuff. An example... GM's crate 3.4L uses a Crane cam (H-260-2) that is very strong. It requires more spring, but GM have sorted this all out and offer a spring and retainer combo that works properly - correct seat pressure with about 0.1" more installed height for the spring with no machine work on the head.
Unfortunately for you and I, this Crane cam is missing the cam position trigger that is used with the 3.4 SFI. There may be other cams out there that would provide a higher level of performance than the stock cam, but you are going to have to shop around and ask the right questions.83 S-10 w/95 3.4 SFI, 4L60E
The additional work I spoke of is getting the springs off and seated back on. Just takes a lot more time94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
