Dash question on speedo - FirebirdV6.com/CamaroV6.com Message Board
  • Dash question on speedo
    I was wonderin if it was difficut to take a Z28 dash/gauge setup and put in my car so i have the 150 mph speedo? is there much work involved? can it just be put in and hooked up and have nothin else to be done or is there som other things that need to be done?
    <a href=\"http://www.sounddomain.com/id/boboboom2\" target=\"_blank\">White 96 RS t-tops Auto 3.08 gears</a><br />Check link for car and all mods<br />USACi Outlaw Spl and SQ competitor<br />Soon to come Batmans SC running 10 psi and PCM programing<br />99 Honda VFR Motorcyle 100.5hp@10,750RPM 1/4 11.14@122mph, 0-60 3.36sec, 0-100 7.92sec<br /><a href=\"http://www.sounddomain.com/id/boboboom\" target=\"_blank\">99 Dodge 2500 Cummins Quad cab 5 speed 325hp</a><br />Check link for all mods and pics
    I have the Z gauges in my car from its "Z cloning days [img]redface.gif[/img] " It works fine and is calibrated to actually tell me the real MPH I am going as opposed to slapping the Z gauges in without the calibration. I dont know who did it or how, but it works.
    White 94 3.4 A4 Camaro<br />Perf:<a href=\"http://www.splmeter.com/94camaro.html\" target=\"_blank\">2.5\" Flowmaster catback </a>, K&N FIPK, B&M ShiftPlus, Aluminum Driveshaft<br />App: 17\" Eagle 077 wheels, rk sport performance spoiler, clear corners<br />Audio: <a href=\"http://www.splmeter.com/box.html\" target=\"_blank\">Drivers side 12\" stealth box</a><br />Times: 10.602@64.2 w/ 2.25 60\' in the 1/8th
      Come on someone has to know if there is anything more involved in this?
        The work itself isn't hard. I have a cluster that I just haven't installed yet. The problem is though that the tach will be off since it's expecting the counting signal from an 8 but is only seeing it form a 6. Other than that, all the other gauges work fine. There has been some disscusion about this a while back. Some one was playing with a module that would fix the tach, then someone else said all you have to do is swap a resistor from the v6 tach to the v8 tach and it works fine, but that seems a little fishy. I'm not sure what the situation is now.
        Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
          Hmm well thats cool then do you know how far off the tach was or is?
