ok my 3.4 camaro wont start.ok this happened before the car wouldnt start and after sitting for like 3 days it started for some reason.drove it like 2 days but it did have some kind of missfire or soemthing like that.the next day I went to start it it just turns over but wont fire?? it has spark and its gettin fuel.
car wont start
check the battery?
maybe its the starter. give us some more details about it and we can better help.
Follow me!
Or this
How do you know its getting spark and fuel? Pull all the plugs and make sure they are sparking when key its turned? Check for spark from the coils?Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
Pull the plug, hook the wire and plug back together, ground out the threads of the plug (make sure they are grounded) and have someone try to crank it... [img]smile.gif[/img]Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
If all of the above doesn't work check your engine bay fuse box on the ignition fuse which should be a 10 amp wiggle it around. then if that doesn't work pull the fuse and twist the legs of it to where you have to almost wedge it back in place. the fuse boxes are real bad about doing that... Ran into it quite a few times in the past couple years at the shop. if that doesn't work let us know.~BLUEICE~
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...1 day ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...3 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
