serious question about engine removal - FirebirdV6.com/CamaroV6.com Message Board
  • serious question about engine removal
    Ok so the story is my engine has a bad knock and I'm pulling it out to have it rebuilt, My question is, is it easier to pull the engine from the top or bottom? I've read all kinds of stuff, but haven't gotten a clear answer. I'm going to do all the work in my 2 car garage. Car is a 1998 Firebird convertible. Anyone have decent pictures so I have an idea of what might be easier? Thanks.
    Re: serious question about engine removal
    Ah, you're in luck, I just finished my bottom swap today. Here ya go.
      Ask me any questions you need, as the whole process is still pretty fresh in my head.
        it would be alot easier to take it out from the bottom...but the way the car has to get jacked up...kinda is freakie lol....
        WAWA-A-HOLIC
          ^ X2 it does look dangerous but it is also pretty quick to do if you have the right stuff on hand.
            X3:rock:
            headers, high flow cat, slp loudmouth
            powerdyne supercharger 6psi
            GT2 cam. all done by myself :banana:
            Hell yea
              I used the 2x4 block tower/jackstand to keep the car up, and left the hoist and chain hooked up to the radiator support for safe measure.
              Notice my old engine was completely disassembled before I took it out. This is unnecessary, you can leave the old engine all together. I just got board :)
              Whereas if you're going to take it out the top, you'll have to pull the intakes and a bunch of stuff top end, as well as most of the front of the car. You can take a look at some top pulls to see how invasive it is.
                Do you lift the body off or lower the engine down after the car is jacked up?
                Also, what are the main parts you have to unbolt to free it up from the car?
                I need to do this soon.
                  you lift the body up after you loose the engine
                  Hell yea
                    You could leave the trans & engine on then use a jack on the trans and engine then unbolt everything and roll it out. That way when you lower it out you can make sure everything is disconnected so nothing rips out or breaks. Either way works.
                      out the bottom for sure
                      http://www.bowtiev6.com/
                        You have the k-member bolts, driveshaft, trans mount, upper strut mounts, steering shaft, fuel lines, throttle linkage, coolant hoses, brake lines, clutch, and wiring harness is the bulk of it. Take pictures of quadrants so you remember where your grounds go and what not. I would also start collecting coffee cans or something to organize and label all of the hardware you will be taking off.
                          ^ What he said! YYou also have to disconnect the front sway bar (4 bolts, easy) and the toque arm (automatic tranny, easy)
                          I personally am a fan of ziplock bags and a sharpie to bvag and label everything and where it goes. It's a lifesaver when yougo to put things back together.
                          But yeah, once you disconnect everything, there are six 18mm bolts that hold the k-member to the body, and the 8 nuts on the strut tower.
                            alright thanks, I might have questions because I'm gonna start this probly tomorrow, and I'll take pictures of my progress. Thanks everyone.
                              I wish i had a garage...fck
