best spark plugs - FirebirdV6.com/CamaroV6.com Message Board
best spark plugs
  • best spark plugs
    I have a 1997 with 107k on it. Its totally stock, what is the best spark plugs i can run in it. Also while im at it im going to run new wires, what do yall recommend. I have new coil packs already.
    There is a search button here. ;)
    http://www.camarov6.com/ubb/ultimate...c;f=1;t=015894
    http://www.camarov6.com/ubb/ultimate...c;f=1;t=015864
    http://www.camarov6.com/ubb/ultimate...c;f=1;t=015611
    http://www.camarov6.com/ubb/ultimate...c;f=1;t=015205
    http://www.camarov6.com/ubb/ultimate...c;f=1;t=013414
    http://www.camarov6.com/ubb/ultimate...c;f=1;t=011752
    http://www.camarov6.com/ubb/ultimate...c;f=1;t=011189
    Matt
    1998 Mystic Teal Camaro M5
      they dont really anwser my question. besides those date back all they way to 2002,, time change and new stuff comes out, and new people join.
        Ok, 1 word: TR55.
        But as you could see by those posts, it really doesn't matter. Everyone has their preference and it won't make any difference.
        Matt
          ok,,thats ngk right? what about wires?
            for the most part plugs are plugs and wires are wires...(slightly differnet if you get into nitrous and boost)
            I have accels, taylors, bosch, and msds... they all pretty much perform the same.
            but for what its worth... I run autolite 605s, I believe, can't remember, a range cooler then stock, read up at clubgp, about alot of n/a L36 guys prefering them. I tried them to check out an issue I had with knock, but had nothing to do with them.
            had TR55s before that.
            I am running MSDs with heat sheething related to this thread... (my screenname was MustangEater)
            imo a great thread about ignition...
            http://web.camaross.com/forums/showthread.php?t=78028
              I have accell plugs, and taylor 8mm wires.
              *Matt
                I use NGK TR55's, and gap them at .058!
                  Turban made no sense there so do not go that route, with a non-productive comment like that he will steer you wrong. :rolleyes:
                  I would highly suggest just buying AC Delcos #41-101 Iridiums, NGK TR55's or standard copper NGK's next time BobbyZ72 . Splitfires are not worth the extra money.
                  I am running the AC Delco Iridiums now and still retain the smoothest idle, therefore no problems. Seafoam that motor of yours then change that oil as well while your under there. Install some high quality wires of your choice with plugs with anti-seize on the threads ( anti-seize is so important ). I have done that and was extremely happy with the results.
                  This spring, I will be testing Denso Iridiums. Spark plug IT-16 with a gap of .060. This is for our Chevy L36 3.8L V6 motor.
                  My '91 Firebird runs on them Bosch Platinum +4's. Another great set of plugs that runs clean and still gives me exceptional gas mileage.
                  MSD Wires? http://www.racepages.com/brands/buy....maro&year=1996
                  Benefits of Platinum Spark Plugs.
                  http://www.babcox.com/editorial/cm/cm120032.htm
                  You wanted a definitive answer, there ya go. More power to ya!
                  [ February 03, 2006, 10:58 PM: Message edited by: 96RS Alex ]
                  Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
                    wrong??? whatever.I have been using these plugs in my 3.4 and they are great
                      Matt
                        exactly^^^
                          this is what i would do when i change my plugs/wires.
                          • 187shark
                            by 187shark
