The title pretty much says it. When I race through the gears and shift over 5kish usually when I get into 3rd gear the check engine light starts flashing and i instantly let off and coast in netrual. I then scan the car and it is normally cylinder 4 misfire. Sometimes it is random misfire. Whats wrong with my car? Have new plugs and wires. I never had this problem when i was an automatic running the auto pcm. When i was running with the M5 with the auto pcm it didnt do it either. It seems now that I am running the M5 pcm it started to do this. I got the pcm from pcms4less.com and had it pretuned for 1.8 rockers. Im supposed to go to NYI on Wednesday to race so i gotta fix this problem soon. Or no race track :(
Misfire when racing through the gears
Re: Misfire when racing through the gears
Sounds a injector is starting to go, mine had a bad one that would misfire and finally found it after a year, replaced wires, coils, plugs and ICM and it was a injector going out. PCMforless can't pretune a pcm for 1.8 rockers, you have to have a wideband setup and have hptuners to do a correct tune on it. Pcmforless is only good for the minor thing like gears,fans top speed, rev limiter, and disable TQ mangement.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I did not, could this be the culprit to my misfire? After doing some research i am starting to think that it possibly is. My friend keeps telling me its not since im not throwing other codes related to the crank. Im going to do a relearn soon and will let you guys know if that solved the problem. Its not the coils or icm since i just swaped them and it still does it.
Everyone likes to relate your problem to the "exact same thing that happend to me." You mentioned you changed your plugs and wires, possibly have a cracked wire or plug? Just do the stuff that is free first to eliminate problems, such as a visual inspection of parts that you have recently replaced. Since you recently did plugs, and the #4 misfire is the code you pull, inspect that wire for melting, and even pull the plug and see if its cracked. Then continue on from there. You just did coils and and icm, so you can eliminate those.Team NoVa
Also, don't change the ICM just yet if you can return it unused. I have found from experience that (I think) the ICM is what tells the PCM there is a misfire. If the ICM is the cause of the misfire, it does not appear to set a code, because it doesn't tattle on itself. So if you were getting misfires w/ no code, I think the ICM would be the culprit. But since you have codes, I'll bet it's something besides the ICM.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Originally posted by Rob Bell View PostI have found from experience that (I think) the ICM is what tells the PCM there is a misfire. If the ICM is the cause of the misfire, it does not appear to set a code, because it doesn't tattle on itself. So if you were getting misfires w/ no code, I think the ICM would be the culprit. But since you have codes, I'll bet it's something besides the ICM.
Incorrect. The PCM uses a stator wheel on the back of the harmonic damper to detect miss fires.sigpic
Originally posted by Cammy98 View PostAutozone checks ICM and coils for free just to cross those off the list
Originally posted by bigbrian442 View PostIncorrect. The PCM uses a stator wheel on the back of the harmonic damper to detect miss fires.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
