How to undo - FirebirdV6.com/CamaroV6.com Message Board
How to undo
  • How to undo
    how do you take these bolts out or whatever they are
    (The Ones In Red)
    http://www.cardomain.com/ride/2151539/6
    <a href=\"http://www.cardomain.com/ride/2151539/1\" target=\"_blank\">http://www.cardomain.com/ride/2151539/1</a>
    id have to look at my car, but i think you just pull them out
      I beleive they are pressure tabs.. They have fins going down the bolt that once are pushed thru the hole lock it into place, you basically just use a screw driver and pry under them, unless you have a pry tool...
      some have locking tabs on the top, you must pull the center tab out, and then pry the rest out.. Theyre pretty simple.
      *Matt
        does it take alot of force or should they come out real easy?
          It depends, sometimes they pop right out sometimes they dont, i actually took some off yesterday, and i broke one, and the others came out free.. they are pretty cheap to replace, you can get a bag of 10 for .86 cents a peice at the dealership, or pick them up at autozone...
          *Matt
            Also, i think they call them plastic retainers, or sustainers, something of that nature at the dealership cuz i called them pressure tabs and the lady thought i was nuts...
            *Matt
              alright i got em thanks
