what the hell should my fuel pressure be at? when i first installed my gauge i was at 48lbs idle and load well a few days go by i am now at 51ish idle and climbs to upper 50s under a load... why is it doing this?
fuel pressure question..
Re: fuel pressure question..
Mines at 48 when first started and at WOT it will go to 52-54 PSi and then after it is hot , my idle at a light will be 46-48 PSI. This is with a Walbro 255 high flow.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Sounds like its running strong so most likely it will go out soon.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by dgreet77 View PostMy stock pump idles at 42.5 or so, climbs to 50 or slightly above under load.
Car used to idle at 42.5 and rise under load as quoted above. Now it is idling at about 50 and goes no where under load. What would cause this? Anything other than a bum FPR?Old Car = 12.679 @ 106.5 on 150 dry shot.
New Car = 2010 3.6l 304hp Camaro
I would start with the FPR. My guess is that the FPR is stuck, but the pump provides enough pressure that it's able to keep the pressure steady, even with more fuel going out the injectors. Try flooring it to see if the pressure drops at all. I think that would be a definite indicator of a bad FPR.
Please no nitrous though LOL2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Originally posted by xcdarrel17 View PostI'm gonna pull this thread up for my question.
Originally posted by EarlR View PostNot sure about the Camaro, but I know other systems use vacuum to the FPR to reduce fuel pressure under no-load conditions. If the vacuum is not there, or the FPR is not working properly the default would be the higher pressure.
The good news is (for you nitrous guys) the FPSS is what saved me at the track and why my nitrous stopped kicking in. No vacuum line hooked up to the FPR means the system couldn't jack the pressure up to where it needs to be with a dry kit. FPSS does it job and doesn't allow the second solenoid to fire = I still have an engine.Old Car = 12.679 @ 106.5 on 150 dry shot.
