My engine takes about 3-4 secs to crank then a puff of black smoke comes out the exhaust. A mechanic told me i had a fuel injector leaking. He looked at my fuel injectors and replaced one that was leaking, it helped a little but it still takes along time to start. It only does this when the engine has sat for a couple of hours.
changed plugs,wires,intake gasket....
what else could cause this or do you think there is another injector leaking that he did not find.
THERE IS A small PUDDLE OF GAS IN FRON OF THE DRIVER'S SIDE MIDDLE INJECTOR(the one i just had replaced)
Is the fuel injector o-rings causing the leak?
[ March 25, 2003: Message edited by: Colt ]</p>
