anyone know if I can install a set of 42# fuel injectors on my 3.4L with stock tuning? would i run the risk of damaging my motor or would it even run at all?
bigger injectors stock tuning
Re: bigger injectors stock tuning
i'm running 6psi of boost for now. Do you guys recommend an adjustable regulator, the speed shop where i'm getting it tuned said that they don't think it will be necessary. i've got a higher flow fuel pump, but it's being held back by the stock regulator.Last edited by ForceFedV6; 09-03-2009, 06:39 AM.
Originally posted by ForceFedV6 View Posti'm running 6psi of boost for now. Do you guys recommend an adjustable regulator, the speed shop where i'm getting it tuned said that they don't think it will be necessary. i've got a higher flow fuel pump, but it's being held back by the stock regulator.
What kind of tuning is your speed shop doing?
yea sounds like the shop you are using has no clue about the 3.4 engine if they think they can just buy a cable.
Use the FMU for upping the fuel with the walbro pump
do they realize that it is different than a lt1 pcm?
I hope they do, when i first went to their shop, they kept on calling it a z28 until they finally saw that the intake manifold said 3.4 on it...these guys originally started their shop with american vehicles, but i'm still concerned about how mine will go since it's their first v6 camaro their tuning. I'll let you guys know how it goes
yea they are in for a nice surprise. lol. You will leave still using that FMU
