Alright... my car started "hopping" on me or boggin down. we replaced the fuel filter which only lessened the problem. it still hops at normal driving, but repeatedly hops and chokes when im under load, i.e. in fifth gear going up a hill pushin down on the gas. just seems 100 times worse that way. What could be the problem? fuel injectors or some god knows what sensor? please help! [img]graemlins/fluffy.gif[/img]
Car bogs down or chokes!
spark plug wires, happened to me around 50K miles not a biggy but it sounds like your engine is going to die on you all the time :DWant to see \"The Sleeper\" Project?<br /><a href=\"http://members.sounddomain.com/0stealth0\" target=\"_blank\"><br />Click here to check my current car out and my project.</a>
Same thing here. Replace the wires and plugs while you are down their. Some of the plugs will have damage from the faulty wires. Mine did at 50K. You can get a custom set of wires for around $4098 Blue Firebird M5 <br />Spintech,Pro 5.0,K&N,Taylor 8mm,02\'TA Rims.
Same thing happend to my 98 at about 55K. I ended up having the plugs, wires, and ignition coil replaced. On the diagnostic it was reading as a "Random Misfire". Luckily they covered it all under the extended warranty.
There was also a recall on the plug wires for I think it was 96 to 99 v6 fbodies.98 Camaro<br />K&N,Free Air Mod,M5,Monsoon,stock Z28 catback exhaust
My engine isnt dying on me yet, it just bogs down and hops. ill try the spark plugs and wires. any tips for easily accessing the damned things? am i going to have to jack up the motor or what? i cant reach em from the top or bottom. [img]graemlins/fluffy.gif[/img]
ps... i also have 110,000K on my car, could there be something worse?vRrOoOoOoOoOOooM
I did have a ses light come on but that was for my bad cat. replaced that and the light went off. thats why im wondering if its something that doeesnt show up on code readers. its such a crazy feeling... i unno. but what i dont get is why this has happened to all you guys at 50K... mines Just now happening at 110k???? [img]graemlins/fluffy.gif[/img]vRrOoOoOoOoOOooM
Definitely spark plugs/spark plug wires. Had the same problem when my car hit 60,000 or so. Felt like it was choking...Going slow was fine, but when I got on it, there was popping from the exhaust and really, really slow acceleration, and plenty of hopping, like something was holding it back. Replaced plugs and wires, and ran stronger than ever.Chris<br />2000 Arctic White Camaro<br />Xenon Body kit. Ram Air II hood.<br />80 series Flowmaster. Ram air induction. K&N filter, 3.42 gears with LSD. <br />\"That which is behind me does not matter.\"
If not your wires and plugs change the coils I bought 3 coil packs from summit (MSD coil packs) for about $38 each I would change those anyway *shrug* Yes you'll have to jack up your car to reach all the plugs unless you have super flexible arms you'll never reach the passenger back plug I got all but that one, from the top of the engine96 3.8L V6 Camaro 5-Speed<br />Vroom Vroom<br />No Power Doors / No Power Locks<br />Removed Jack and Spare<br /><a href=\"http://www.cardomain.com/id/mikerob283\" target=\"_blank\">CarDomain - Mikerob283</a>
