Ok random really weird question. You know how there is that lovely MAF sensor housing that sits right in the middle of the tb? Which makes it an absolute ***** when you are porting the tb? Would it be possible to machine out that tb and re-install the MAF sensor in a separate aftermarket MAF tube? I've seen them for the L36 believe it or not and the simply hold the sensor alone by itself without any housing intside of the tube. So am I crazy?
serparate MAF sensor?
Re: serparate MAF sensor?
Or you can machine it to accept the 99 up MAF. You still have to do a bunch of MAF tuning with HPT. I would suggest keeping the screen as the MAF is not very stable with out it. This TB does still accept the screen and the AFR stays more consistent with it in place.
Yes you can either run a seperate LS1 style MAF or use a 99+ MAF in it. However our tb's are massive already and flow way more than what our engine can take it so you end up gaining very little if anything.
Save your money and time for other mods that are worthwhile. I have done it in the past and so I am not just going off what I have read. It was a waste of my time.
Originally posted by 97rs4life View PostYes you can either run a seperate LS1 style MAF or use a 99+ MAF in it. However our tb's are massive already and flow way more than what our engine can take it so you end up gaining very little if anything.
I would agree your money is better spent elsewhere. The only real difference I have seen is a more stable AFR then with the 98 down MAF. Then again this didn't cost me anything.sigpic
ya I suspected that but i was porting it and the thing is so god damn frustrating to get to all the parts to port it, I ccouldn't help but just be like....seriously....is there any other way?! lol I mean I have a dremel tool with a flex hone and it is still one GIANT pain in the ***!
when I was messing around with my spare back in the day I cut out metal shaft (maf housing for the 95-98 tb) with a saw saw, then smooth it out with the dremel. Cut the time down on it. But again, just stop now and leave it stock or just polish it up. You will need HPTuners to tune it if you start messing with the size of the TB and the different MAFs
Originally posted by 97rs4life View Postwhen I was messing around with my spare back in the day I cut out metal shaft (maf housing for the 95-98 tb) with a saw saw, then smooth it out with the dremel. Cut the time down on it. But again, just stop now and leave it stock or just polish it up. You will need HPTuners to tune it if you start messing with the size of the TB and the different MAFs08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...4 weeks ago
