I think they are pretty much the same thing except the cold air intake gives it slightly colder air but the short ram is supposed to give you a little bit better throttle response, i'm not 100% though. But for the time being you can give this a try too.
I dont know if its the same tubing but ideally it should fit with some small modifications.
as for ram air I believe those type of intakes are set up assuming you have a hood scoop that will ram the air through the scoop and into that intake such as the SS hoods, ultra z hood, ws6 hood, etc.
Cold air intake is pretty much anything else that will bring cold air into your engine.
I ended up buying the slp cai for the v6 3.8. I hope get some kinda gain out of this, I'm not expecting much because everything else is stock....for now
The panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...
