Intake Gasket Install - Upper/Lower - FirebirdV6.com/CamaroV6.com Message Board
  • Intake Gasket Install - Upper/Lower
    So my radiator fluid kept disappearing with no white smoke out the exhaust, clean oil (i.e. no brown milky liquid), and no leak signs on the ground. So I could only conclude it was being sucked into the intake and being burnt up (not to mention gas mileage of 15.2 mpg city). So I took two days working alone from 9am-4pm to get it done. Here are a few pics.
    Lessons Learned:
    1) Mechanic gloves would have been nice (wtf was I thinking?)
    2) The two plastic elbows, one from the intake manifold to the heater core bypass piece and the other from the heater core bypass piece into the engine, BOTH broke and were stuck inside each end (had to use a screwdriver to pry out). Both were in a package at the auto store, LIFESAVER.
    3) Two leftover bolts.... They were clean bolts so they weren't internal. Oh well!
    4) One more leftover bolt for the drivers side bracket that holds the studs the coil packs connect too. I left this off because it was a PITA to get out and served no purpose since there are two other bolts holding it on.
    5) A couple rubber vacuum connectors broke, busted the coolant temp. sensor. Careful with the plastic part, it was brittle.
    That was about it. Got everything back together and it started fine. Then 4 blocks later..... cylinder misfire. No spark on number 4. Switched coils... SAME result. Concluded it was the ICM. 150 dollars later.... runs like a pro!
    4 blocks AFTER that, turn on the air, horrible grinding noise/vibration when the compressor comes on. At this point I am feeling cursed. So anyways, new A/C compressor comes in this week and I swear if another thing goes wrong, I'm driving this car off a cliff (but there aren't any in FL, SCREWED AGAIN!).
    Anyways, that's my story!
    <a href=\"http://home.comcast.net/~smpuskas/\" target=\"_blank\">http://home.comcast.net/~smpuskas/</a><br /><br />3A C-Fiber Pedals<br />Free Ram Air Mod + K&N<br />RK Sport Air Temp. Module<br />Flowmaster American Thunder 2.5\' Cat-Back<br />Chrome/Red Shifter<br />White Rally Stripes<br /><br />Audiobahn 12\' AE1200 Sub<br />Bazooka EL 1500 Class D Amp
    Re: Intake Gasket Install - Upper/Lower
    Question, in pic IMG_0549.jpg and IMG_0550.jpg you can see the nearest driver's side cylinder intake passageway is brown and the rest are black. Is it safe to assume that the radiator fluid was leaking into this intake passageway? What are your opinions? Why are the rest black, were they manufactured that way or is that oil residue? None of the black or brown would clean off.
      Its just carbon build up even if you polished it out it would come back , I guess the brown one is where the anitfreeze was leaking.
