97 bird, ive been having a ticking noise coming from the drives side of the engine that i thought was an exhaust leak but cant find it. i put oil and seafoam in through the brake booster vaccumm line and couldnt see any smoke coming out. its worse when the engine is cold but i dont seem to hear it when its raining and seems to run better. ive started to hear lifter noise from the same side of the engine and now im clueless. any suggestions? thanks
exhaust leak?
Re: exhaust leak?
does the ticking get louder/faster under throttle? can you smell any fumes?
are you running headers or stock manifolds?pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
gone in body, but not in spirit
Re: exhaust leak?
Same thing my car did on the drivers side. Turned out to be a broken manifold stud. Closest bolt to the front of the car. It would get quieter as the car warmed up. But that's ur most likely problem.auto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
New Time:
15.11@91.14
Team 3M Mafia
New Times coming soon
Re: exhaust leak?
double check your egr fitting...mine leaks through there...
Re: exhaust leak?
Originally posted by whitdog54 View PostI had same problem, tightened up my pacesetter headers...it went away. But now its back, I think I fried the gasket.pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
