Cat - FirebirdV6.com/CamaroV6.com Message Board
Cat
  • Cat
    so iv noticed a rattleing sound coming from under my car and am pretty sure its the cat now i have a california emissions cat on it. and last time i went in for a new cat the shop told me i could only put a california cat on it. I live in new york can i just put a regulation catalytic converter on the car because all the california cats are extremly expensive. thanks
    Re: Cat
    if you dont live in california, why the hell would you need a california cat?
    yes you can put a regular cat on
      Re: Cat
      the shop said they wouldnt touch it without a california cat. bought the car used must have came from there
        Re: Cat
        I hate shops and their cat rules. However, i'm sure if you look around someone will put what you want on your car. But I'm always for doing it yourself.
        TEAM C6V6
          Re: Cat
          if i could weld i would so do it my self.
            Re: Cat
            Hell I couldn't weld when I did mine like, 3 years ago. But I got it done lol.
            TEAM C6V6
              Re: Cat
              I would fine a different shop that would do it , or some private guys will have adds for welding might try that. The ehaust guys that did mine said aslong as it doesn't through a code they would do it, and after I showed them what Hptuners does they didn't have a problem since AZ doesn't check anything except scan ODII codes. Don't even pop the hood.
                Re: Cat
                they're just lying and trying to get you to foot the bill for a california cat. It doesn't matter where the car's from, it's where it's registered/tagged. Go to a different shop
                  Re: Cat
                  after asking my friend, if the car had a cali. cat on it, one has to be put back on it.
