Vacuum Pressure - FirebirdV6.com/CamaroV6.com Message Board
Vacuum Pressure
  • Vacuum Pressure
    I have looked all over and have not found anything.
    What is the correct idle vacuum pressure on the 3.4l
    Re: Vacuum Pressure
    im confused by your post, what are you looking for?
    vacuum from the intake?
    fuel pressure?
      Re: Vacuum Pressure
      Vac. should be about -18 to -22 at idle and around -10 while crusing, unless you have a big cam then you might see -12 or -14, I have a mild cam and it dropped mine to -16 to -18 but runs smoothly. WOT of course is going to be 0.
