I've just recently noticed my car wants to sputter/ backfire when i'm driving. There's no problems on startup and revs up to about 2k, but once i hit between 2300-2500 rpms the exhaust begins to sputter and the car shudders. I just had my spark plugs, wires, fuel filter, and an oil change done today and i still notice the problem. Is there a possible clogged CAT? A recent mod i've done was the pvc mod with the shaved air lid, could any of those have affected the enging causing the sputtering?
Exhaust sputter problem... NEED HELP!
Re: Exhaust sputter problem... NEED HELP!
I would say one of your spark plug wires is arching or isn't on all the way. I would take it back to where you had it done and let them fix it, but it should be a plug wire. If they try to tell you diffferent there just trying to get more money out of you. I would buy a Haynes manual and start doing the easy maintance stuff yourself, you'll learn more about it and save alot of money.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Holy crap, I ran into this problem in high school auto, a buddy of mine with a 3.4 Manual had this exact issue. We never resolved it (its HS auto and we had a week to do it.)
Changed the fuel pump, no difference, even the muffler fell off and it still did it. That was as far as we got.
Well, I havent really talked to him since. I could give him a call though.
I want to say that its not a sensor, because every scan tool we hooked up showed everything was reading right. BUT DONT TAKE MY WORD FOR IT. Never believe in a scan tool, its helpful to guide your diag, but its bad practice to believe in it as law.
yea i already had the o2's scanned and were told they're working fine so i need to find a mechanic who knows what he's doing or find somebody else with the problem that actually fixed it. I remember though when i stored my car over winter i put Sta-bil in and the car ran kinda rough after i let it sit for a few minutes after adding the stuff. i'm wondering if maybe i just need to run a few tanks of gas through the car to be totally rid of the sta-bil or if it's something bigger.
The thing I find frustrating about forum-diagnosing is its purely third party. I'd love to get my hands on your car and start testing! I've got ideas, but its not practical to try over a forum. Sorry, but best bet is a shop. Plus you get a warranty! Hopefully..
Man, I get excited fixing other peoples stuff, but I pissed away time putting my engine in today. 5 HOURS to get it in and transmission hooked up and get it ready for a radiator.
I had this problem minus the backfiring. mine was cylinder 3 misfire. I started with the plugs and wires. it ended up being the coil pack. I needed to change the plugs anyway and glad I did. I found 2 of the plugs wasn't tightened at all. turned them a couple of times by finger and they fell out. that is what probably caused the coil pack to go bad. I assume whoever changed the plugs before I got the car had hell getting into the tight spots like I did but you have to make sure you get those plugs tight enough to stay in.
this.
http://shop.oreillyauto.com/product_...d/ec3045-1.jpg
Sometimes they go out and at certain times throughout the throttle range. it will send the wrong parameters to the ecm and cause the car to have incorrect fuel mixture and cause it to (miss, bog down,lose power, and wanna stall)
Its on the throttle body. on the left side.
