plastic coolant elbow - FirebirdV6.com/CamaroV6.com Message Board
  • plastic coolant elbow
    I have a 2002 firebird 3800 engine that I am replacing the upper and lower manifold gaskets. I see in some of the posts that there is a plastic elbow that is prone to break. anybody got a part number for that elbow? (O'Reilly, AutoZone, Advance Auto, etc.) I called O'reilly but the counter help could not find it. Any help today would be greatly appreciated because I am getting started on it tomorrow.
    Re: plastic coolant elbow
    iirc, I got mine from gmpartsdirect... the plastic elbow goes from the lower intake manifold to the tensioner pulley/alternator bracket. On my car there are actually two plastic elbows, but on other cars the metal of the bracket turns 90* and goes into the hole, instead of having a second piece... I can't remember which years are which...
    My reccomendation would be to get that piece off and take the plastic elbows (or the pieces of them) to a parts store and see if they have a replacement... if they don't have it then you can go to a dealer parts dept and they should have it. If you can wait for shipment, then you can order them online...
    https://www.zzperformance.com/grand_...=370&catid=103
    If you only need one, then check the description, it explains which is which.
    GL
    Custom interior...
    TEAM NoVa
      I don't recall the part number, but you can find it in the "HELP" section at Autozone and other parts stores. It's a common part used on different vehicles.
      '99 Camaro
      '04 Saab 9-3 Aero
      '90 Audi Coupe Quattro
        upper elbow GM p/n: 24503423
        lower elbow GM p/n: 12565082
        ^in case you need to go to a dealer, here are the part numbers for the two elbows
        Custom interior...
        TEAM NoVa
          Thanks for the advice. I was able to find the 2 elbows which one was the leak (one above the water pump) instead of the intake gasket. It had became brittle and broke. the other one came apart when the belt tensioner came off. That was a relief to not replace the intake gaskets.
            Just make sure that you get all of the plastic out of the holes before you try and install the new ones... I've done this to two engines, one with two elbows and one with one, and on all three there was a ring of plastic that broke off and got wedged in there, in both the manifold and the tensioner bracket... they came out easily, though...
            Custom interior...
            TEAM NoVa
              Hey fellas, sorry for the bump, but I wnt to a shop and they sai dof I were'nt careful, I'd be pulling the intake manifold. Sensationalist bs? Or genuine concern? I'm changing this out today...
                You'll be fine.
                  Just try not to push the little o-ring seal into the coolant passage if the elbow breaks. Mine fell in while trying to get it out and it took 30 minutes and scraped knuckles to get it back out.
                  '99 Camaro
                  '04 Saab 9-3 Aero
                    So far so good.
                    Part that goes into the block broke. Dang...
                    Okay well putting it back together...the lower elbow fits very loose. Hope this isn't a fluke.
                    Done! Everything seems okay, even the loose fitting elbows. Running it through its paces.
                      The elbow is pretty easy , there only one on my 96'.
                        I know this is kinda off topic, but I always wonderd if you were to tap and plug both hole, the one in the LIM and the one in the Front cover, would it cause a problem? I always just kinda wonderd about that.
                        Daily: '02 Black Yukon Denali
                        Toy: '06 Torrid Red GTO
                        Gone: Powerdyned '02 Pewter Camaro
                        Gone: '07 Charcoal Yamaha R6
                        Gone: Ex-wife, lol
                          I'd say it would...that's what coolant runs through right?
                            Thats not the only place it flows through. They simply provide supply to the heater core. i was just looking at plugging them as the same thing as putting a peice of hose between the in and out on the tensioner assembly.
                            Gone: Ex-wife, lol
                              Couple questions...
                              I don't remember, but is the one on the lower intake manifold, connected to the belt tensionor?
                              Also is the lower intake manifold one, accesible without pulling the TB or anything else?
                              My tensioner is bad and I will be replacing it soon and considering replacing both while I have it unhooked.
